Piezoelectric Energy Harvester Project
The project aims to design a small-scale piezoelectric ramp to generate power through force application, serving as a proof of concept. A vertically aligned piezoelectric ceramic (PZT) will be used, with a focus on demonstrating the conversion of mechanical force into voltage. Due to high costs for larger materials, the model will be compact, approximately 4cm x 2cm, with a budget of $200. Energy will be stored in capacitors to charge a battery, although the project does not prioritize design specifics. It is noted that piezoelectric elements require varying forces to generate a consistent energy output.
JMack23
I am undertaking a project to design a piezoelectric ramp (small scale model) to generate power when force is exerted upon it. The project is simply proof of concept but in principle I thought a piezoelectric ceramic (PZT) aligned vertically with a hinged ramp exerting the force on the Piezomaterial (similar to orienting a piece of piezoceramic near the hinge of a door then closing the door causing the Piezoceramic to deform and so produce voltage.
Since these materials seem prohibitively expensive at the larger dimensions that would allow this to generate useable power, my scale model is going to be very small indeed (around 4cm x 2cm seems to be what i can get for 200USD) I am hoping to store the energy in capacitors which when filled will charge a battery.
I am not too interested in the ultimate design or anything for this project, I just need to demonstrate the principle of force being converted to voltage and ideally storing it somehow. There is surprisingly little information online so far, but it is an idea that interests me a lot.
Does anyone have any pointers or experience in endeavours of this type, are there any glaring mistakes in my assumptions, thanks in advance!
Keep in mind that a piezoelectric element can't gather a constant stream of energy from a constant force- the force must be varying in time, sinusoidally for example.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
