Arithmetic mean of two unknowns in a system of equations
The discussion revolves around finding the arithmetic mean of two unknowns, x and y, from a system of equations. The initial approach incorrectly treats the problem as a statistics issue, leading to an erroneous mean calculation. The correct method involves solving the equations to find the values of x and y first, which yields a mean of 7.5, contrasting with the incorrect result of approximately 8.28 from the initial method. Clarification reveals that the arithmetic mean should be calculated from the actual solutions rather than through a statistical shortcut. Ultimately, the simplest and most accurate approach is to solve for x and y before calculating their mean.
travism123
When finding the arithmetic mean in a system of equations is there any reason why the method that I am using is wrong?
Find the arithmetic mean of x and y in the following set of equations
3x + 5y = 65 and
7x + 14y = 175
I treated it as a statistics problem where x's and y's are individual units, so...
10x + 19y = 240
mean = 240/29 since mean = total sum/N My answer is 8 and 8/29
I understand that this method might not be the correct way of doing it, but if the number of units is known (10x, and not 10xy) is there any reason that this method of finding the arithmetic mean will not work.
Thank you to anyone who takes the time to look at this. :smile:
Yes. See below.
3x + 5y = 65 and
7x + 14y = 175
10x + 19y = 240
You can do this, but it is of no help.
This part is not valid. If the left side were 10x + 19x, you could combine these terms to 29x, and it would make sense to divide by 29.
The more obvious approach to this problem is to find the solutions x and y to the system of equations, and then find the arithmetic mean of these numbers. This system can be solved pretty easily, giving integer solutions.
Thank you Mark.
I guess that I still don't understand why this is wrong. If I solve the equations I get:
x=5 and y=10
So the way that I am looking at it, I have a group of ten 5's and nineteen 10's. If I want to find the mean value for this group then wouldn't it make sense to add them to get my total sum, or 240, and then divide by N, or 29.
x and y are equal between equations, so I am not looking for the mean of x and the mean of y, only the mean of every unknown in the set of equations, or x and y together.
Obviously I would need to solve the equations first if there were an equation with an unknown being multiplied by an unknown like: 10xy + xy + 14y = 392. Then I completely understand why this would not work, but if I know the exact number of x's and y's why can I not simply add the n of each group together to get my N, and then divide the total sum by N?
In the end, isn't it accomplishing the same thing as solving the equations to integers, and then finding the mean.
Just to clarify...I am only looking for the correct answer, and not the correct method. The way that I did it originally seems to be a big shortcut.
Again, thanks very much.
Well, no, because you get different answers. The arith. mean of 5 and 10 is 7.5, which is different from the value you got, which is about 8.28.
What you have said makes some sense, but I have never seen a problem where you are expected to take a system of equations and do anything but find its solution. I guess some context for this problem would be helpful--can you give us the exact wording of the problem?
I am positive that you are right Mark.
The actual question was easier:
If a + 2b = 14 and 5a + 4b = 16 what is the average (arithmetic mean) of a and b?
(a) 1.5
(b) 2
(c) 2.5
(d) 3
(e) 3.5
The answer is 2.5.
(6a + 6b = 30)/6 = a + b = 5
5/2 = 2.5
I think that I made it more complicated than necessary. Thanks, and sorry for taking up your time with something so obvious.
No problem. I don't mind helping at all. A favorite saying of mine is, "Keep things as simple as possible, but no simpler."
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
