How do you calculate the resistance in a coil?
  • Thread starter Thread starter Sirsh
    Coil Resistance
Calculating the resistance in a coil typically requires knowing the material's resistivity, which can be derived from the coil's dimensions and material type. While voltage and coil diameter are useful, they alone do not provide enough information to determine resistance without the amperage value. An ammeter can measure current directly, but alternative methods involve using the formula R = V/I, where R is resistance, V is voltage, and I is current. Additionally, the resistance can be estimated using the coil's length, cross-sectional area, and resistivity of the material. Understanding these principles is essential for accurate calculations in electrical applications.
Sirsh
Hi all. I'm just wondering if it is possible to calculate the resistance in a coil without the amperage value? I've got voltage,coil-diametre, amount of turns, coils material type.
The only way i think it is possible if i set a ampmetre into the circuit. is there any way?
Thank you.
Thank you.
Google "resistivity"
