Engineer Needed: Interview for Engineering Class (10 Questions)
An individual is seeking to interview someone with a mechanical engineering degree for a Principles of Engineering class, requiring responses to ten specific questions. The request is made in a forum setting, where the poster expresses uncertainty about the appropriate section for such inquiries. However, the forum moderators have indicated that interview threads are no longer permitted due to privacy and anti-phishing concerns. As a result, the thread has been closed. This highlights the importance of adhering to forum guidelines when seeking assistance.
mattd40
For my Principles of Engineering class, I need to interview someone with an engineering degree (preferably in mechanical engineering) and working in the engineering field. There are only ten questions. If you are willing to help me, please post a reply and i will pm you the questons. Thanks!
Sorry if this was supposed to go into the homework section, but it looks like that has a specific format that needs to be followed and this doesn't seem to fit.
Sorry Matt. For privacy and anti-phishing reasons, the PF no longer allows interview threads. Thread closed.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
