What is the Difference Between Escape Velocity and Orbit Velocity?
  • Thread starter Thread starter Badger01
    Escape Velocity
Escape velocity is the speed needed for an object to break free from a planet's gravitational pull, calculated using the equation GMm/r = 1/2 mv². In contrast, orbital velocity refers to the speed required for an object to maintain a stable circular orbit around the planet, which is derived from the centripetal force equation F = mv²/r. The confusion arises in distinguishing these two velocities, as escape velocity is greater than orbital velocity. Specifically, escape velocity applies to an object leaving the planet's surface, while orbital velocity pertains to an object in a circular path at a given radius. Understanding these concepts is crucial for grasping the dynamics of motion in gravitational fields.
Badger01
"Given a planet has mass M and radius R, find the speed it would have to be launched at. Compare this to the speed required to put the object in the circular orbit."
I understand the first half where Ep=Ek
i.e: GMm/r = 1/2 mv2
rearrange to find v
how ever, I'm unsure of what exactly the 'orbit velocity' is.
is the the value of v in centripetal force, F = mv2/r
is this the same as the speed needed to launch it into orbit or what? i am rather stumped here..
The problem statement is a bit confusing. I suppose it could be asking you to compare the escape velocity for an object leaving the planet's surface (planet radius R) to the velocity of a hypothetical object orbiting the planet at the planet's surface. Obviously one would have to ignore the problem of terrain variations, such as mountains!
To answer your query, yes, the orbital velocity is the speed of the object along its orbital path. So it is indeed the 'v' in mv2/r.
