Non-uniform Inertia of a Cylinder: I = (3MR^3)/5
  • Thread starter Thread starter LASmith
    Inertia
The discussion revolves around calculating the moment of inertia of a cylinder with a linearly increasing density, expressed as ρ = ρ₀(r/R). The initial attempt at the solution involves integrating the expression for inertia, I = ∫r² dm, but the challenge arises in expressing the result without the variable ρ₀. To resolve this, participants suggest finding the total mass M in terms of ρ₀ through a similar integration process. Once M is determined, it can be substituted back into the inertia equation to eliminate ρ₀. The final goal is to confirm that the moment of inertia is I = (3MR³)/5.
LASmith
A cylinder with radius R and mass M has density that increases linearly with radial distance r from the cylinder axis, ie. \rho=\rho_{0}(r/R), where \rho_{0} is a positive constant. Show that the moment of inertia of this cylinder about a longitudinal axis through the centre is given by I=(3MR^{3})/5
I=\intr^{2}.dm
volume = 2\pirL.dr
I=\intr^{2}\rho.dv
=\int(r^{3}\rho_{0}/R.)dv
=\int(r^{3}\rho_{0}/R.)(2\pirL).dr
integrate between 0 and R to obtain
2\rho_{0}\piR^{4}L/5
However, I do not understand how to express this without using the term \rho_{0}
Find an expression for M in terms of ρ0.
I realize this, however as the density is not constant, I am unsure of how to do this.
Set up an integral to solve for the total mass, just like you set one up for the rotational inertia.
Once you get M in terms of ρ0, you can rewrite your answer in terms of M instead of ρ0.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
