Dissociation energy of two particles-variables only equation-mastering physics
The discussion centers on the potential energy equation for two atoms in a diatomic molecule, specifically addressing the stability of equilibrium and the energy required for dissociation. Part a concludes that the equilibrium is unstable, as the potential energy function indicates a local maximum. In part b, the user struggles with calculating the energy needed to separate the atoms to infinity, mistakenly believing the integral results in negative infinity. Responses suggest reevaluating the limits of integration and understanding that the area under the curve does not equate to infinite energy. Proper interpretation of the potential energy function and its limits is crucial for solving the problem accurately.
Same-same
The potential energy of two atoms in a diatomic molecule is approximated by U(r)= ar^{-12} - βr^{-6}, where is the spacing between atoms and α and β are positive constants.
From earlier parts of the equation, it has been that determined that force between two atoms as a function of r is
F(r)= 12ar^{-13} - 6βr^{-7}.
and that the equilibrium distance between them r_{min} is
\sqrt[6]{2α/β}
Part a: Is the equilibrium stable? (My note: a stable equilibrium is a local minimum in a potential energy function. An unstable is a local maximum)
Part b:
Asssuming that the molecules are at said equlimbrium distance apart, find the energy required to bring the molecules an infiinite distance apart., and express this equation in terms of α and β
W=∫ F dr= ΔU
3. The Attempt at a Solution
To part a:
Since potential energy is negatively related to displacement, and there are only two scenarios where Force could be 0 (at this distance or at infinity), I believe this equilibrium is unstable.
to part b:
∫^{∞}_{equilibrium} (12ar^{-13} - 6βr^{-7}) dx
which appears to be negative infinity, which I'm fairly certain is wrong.
Part b is what's really giving me problems. I'm not sure exactly what I'm looking for; I've honestly never dealt with dissociation before. I considered integrating the potential energy function from 0 to infinity, but that would give me the wrong units. Perhaps I'm looking for an energy equal to the maximum potential energy possible with the function?
Any help would be greatly appreciated
Thanks in advance!
Part a: You might want to look up what a local maximum or minimum of a function is, and how to tell one from the other (hint: telling a maximum from a minimum has to do with the sign of the 2nd derivative at the max/min).
Part b: I don't think you are evaluating your limits correctly. Infinity to a negative power puts it in the denominator. If you divide a number by infinity what do you get?
"Part b: I don't think you are evaluating your limits correctly. Infinity to a negative power puts it in the denominator. If you divide a number by infinity what do you get? "
My thought process (which may very well be wrong) was as follows "At infinity the function should be zero, but the area under the curve to get there appears to be infinite."
You are right about the function approaching zero as it heads out to +- infinity, but that doesn't mean the area under the curve is infinite (unless you integrate over zero in the case of your function). Maybe if you plot it this will be easier to see.
