Solving a Mini-Lab Homework Problem on Velocity and Displacement
The discussion centers on calculating the vertical and horizontal velocities at takeoff during a long jump, as well as the resultant velocity and angle of takeoff. The participant collected data showing a displacement of 1.175 meters and a time of flight of 0.49 seconds. Initial calculations yielded a vertical velocity of 2.40 m/s, a horizontal velocity of 2.40 m/s, and a resultant velocity of 3.39 m/s, with an angle of takeoff approximated at 45 degrees. Clarifications were provided on using the Pythagorean theorem for resultant velocity and the relationship between vertical and horizontal components to determine the angle. Understanding these calculations is essential for accurately solving similar problems in future assessments.
xgeek
For my class we did a mini-lab that asked us to stand still and long jump. Kind of confused about how to solve because our teacher is horrible. I am supposed to calculate the vertical velocity at take off (which I thought was 0m/s but someone told me it's at the peak of the jump), the horizontal velocity of the takeoff, and the actual (resultant) velocity of the takeoff. I am supposed to calculate these values from the data I collected
displacement = 1.175 meters
time of flight = 0.49 seconds
I have some answers calculated trying to check them. Also supposed to get the angle of takeoff, but everyone in my class said that it is 45 degrees...
Thanks for taking your time to read this! Problem is for 10 extra points on our next test, well there will be a similar bonus question and I want to be able to understand how to do it correctly. Hopefully the values I collected will match some of the help I get. Thanks!
vf=(vi)+(a)(t)
vf^2=(vi)^2+(2)(a)(d)
d=(vi)(t)+(1/2)(a)(t^2)
vertical velocity at takeoff I got = 2.40 m/s
horizontal velocity at takeoff= 2.40 m/s
actual (resultant) velocity at takeoff= 3.39 m/s
angle of takeoff = 45 degrees
You'll have to show how you calculated your results before we can comment (beyond saying that they don't appear to be correct...)
messed up. I got 2.40 m/s for the horizontal velocity, and also got 2.40 m/s for the vertical velocity. then I took A^2 + B^2 = C^2 to get resultant velocity. can't remember what i wrote on my paper, 3.39 m/s maybe? from there I did sin-1(2.40/resultant) and got 45 degrees
all from memory
If the vertical and horizontal components of the velocity are essentially equal, then the angle should be very close to 45 degrees. tan^{-1}\left(\frac{v_y}{v_x}\right).
Horizontal Velocity
1.175 = Vh (.49) + (1/2)(0.0)(.49)^2 <-horizontal is constant therefore a = 0
1.175 = Vh (.49)
2.397 m/s = horizontal velocity
vertical displacement = (0.0)(0.245) + (.5)(-9.81)(0.245)^2
dv = 0.294 m
Vertical Velocity
0.0^2 = Vi + (2)(-9.81)(.294)
2.40 is the vertical velocity
then Pythagorean theorem for the resultant 3.39 m/s
sin-1(2.40/3.39) = 45.069 degrees
The time it takes to fall from a height 'h' under the influence of gravity is:
<br /> T = \sqrt{\frac{2h}{g}}<br />
Since the path you took as you flew was a parabola the time it took to reach your max height is equal to the time it took you to fall which is given by the formula above; from this you can calculate your max height and from this you can calculate the vertical part of your velocity.
From the period you can also calculate the horizontal part of your initial velocity since you know time and displacement.
The total velocity is the square root of the sum of the squares of the vertical and horizontal parts.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
