Expanding a gas through a valve or through a turbine
Expanding gas through a turbine results in a colder temperature compared to expansion through a valve due to the distribution of potential energy. In valve expansion, most potential energy converts to kinetic energy of the gas molecules, increasing their random motion and temperature. Conversely, turbine expansion converts some potential energy into mechanical work, reducing the random kinetic energy of the gas molecules. This leads to a lower temperature in the gas after expansion. The discussion references the First Law of Thermodynamics, explaining the relationship between heat energy, internal energy, and work done during the expansion process.
charlie95
Can somebody explain to me why the temperature gets colder when expanding through a turbine versus expanding through a valve.
Please explain with equations.
somebody must know this...
Hot gas under pressure stores some potential energy, rather like a compressed spring. This energy is released when the gas expands. If you let the gas out through a valve, almost all of the potential energy goes to speeding up the escaping stream of gas, and this ends up as random kinetic energy of the gas molecules as they bounce around. If the gas expands through a turbine, some of the potential energy ends up as kinetic energy in the rotating turbine, so less ends up as random kinetic energy in the gas molecules.
Less random kinetic energy in the same (after expansion) volume of gas means a lower temperature.
thank u Nugatory:)
But I think somebody once explained to me somethng about dQ=dU+dW.
And that when we expand throgh a turbine, work(dW) is done and therefore we get a much colder gas instead of just expand through a valve.
Is this just ********? :):)
If there is some logic in this, can someone please explain to me what dQ,dU and dW means??
dQ is the change in heat energy or enthalpy of a substance
dU is the change in internal energy of a substance
dW is the change in energy due to the work of a substance.
It's not BS. It's the First Law of Thermodynamics.
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
