Why is my LED glowing without any input when using 7402 ic?
  • Thread starter Thread starter sandeepmrocks
    Ic
The LED glowing without input when using a 7402 IC is likely due to the high input impedance of CMOS logic gates, which can pick up noise from the environment. Unconnected inputs can act like antennas, causing the gate to interpret this noise as a logic signal, resulting in the LED lighting up. When inputs are connected directly to 0V or VCC, it stabilizes the input and prevents noise interference. Therefore, it's essential to connect all unused inputs to a defined voltage level to avoid unpredictable behavior. Proper circuit design should always account for this to ensure reliable operation.
sandeepmrocks
Hello everyone...!
i have made different logic gates using 7402 ic (quad 2-input nor gate ic). what actually occurs is that after joining different gates for making "and" gate & "or" gate until i give the input the LED glows( i have connected the negative terminal of LED to negative terminal of battery and the output of final nor gate to the positive terminal of battery).
But before giving high or low input on any of these gate (i.e. 0 volts in the input terminals), the bulb glows, but as soon as i connect low voltage source (i.e. 0 input) the bulb doesn't glows(which should happen)..
so i didn't found it why the LED was glowing when i didn't gave any input. Can anyone please help?
If you leave any of the inputs disconnected the voltage on that input is undefined.
CMOS logic gates have a very high input impedance. The pins on an unconnected input can act like an aerial and pick up noise (static electricity, induced voltage from the 50/60Hz mains or even radio waves). The results are unpredictable, the logic gate may well amplify this noise or treat it as a logic 1 or 0 causing the LED on the output to light up.
It's quite possible the LED is flashing at 50 or 60Hz or trying to flash at radio frequencies!
When you connect the inputs to 0V (or VCC) with a wire you not only force the input to be a logic 0 (or 1) but you also change the impedance of the input node and this stops the input picking up noise.
When you design a circuit all unused/spare inputs should be connected to 0V or VCC.
thanx CWatters
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
