Can a gyroscope be used to stabilize a levitating globe?
  • Thread starter Thread starter sagitta
    Project
A student is working on a project to create a levitating globe and has explored methods to overcome Earnshaw's theorem, focusing on using eddy currents and a feedback circuit to control electromagnet strength. The feedback circuit is preferred for its potential stability, despite requiring more calculations and soldering. The student is intrigued by the possibility of using gyroscopic motion for stabilization but questions the feasibility of integrating a gyroscope within the globe without a spinning mechanism. Concerns are raised about the complexity of balancing a spinning interior with a static globe. Ultimately, the project will likely proceed with the feedback system approach for stability.
sagitta
Hello,
I am a student and this semester I am doing a project in Experimental Physics class. We plan to make a levitating globe! We have already researched on methods of overcoming Earnshaw's theorem and chose two:
1) Using eddy currents to stabilize an object (conductor)
More or less simple design, but requires too much voltage.
2) Using a feedback circuit to control the strength of the electromagnet.
We have already found some SOP and will research more and figure out by ourselves. This 2nd method is currently chosen as the main one.
But I have been thinking about levitrons and how they use gyroscopic motion to create the equilibrium point... Usually it requires a spinning top, which is not convenient since we need to have a globe. But I was thinking about gyroscopes and this idea fascinates me.
Is it possible to somehow install a gyroscope inside the globe to stabilize the levitation? Is there sort of a gyroscope that doesn't need to be spinned beforehand like spinning tops?
- Spinning magnets as support should be possible
- A spinning interior for a static globe... I think that needs an additional motor in the globe, and it sounds tricky to balance.
Spinning magnets? By "support" you mean as a base or the globe?.. Because I think the globe is supposed to be static...
I guess we'll stick to the feedback systems, they require some soldering and more calculations but seem to provide more stability.
Thank you for the reply!
The base, which allows levitation of the globe.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
