Why when water is heated it's volume first decreases and then
  • Thread starter Thread starter mia5
    Volume Water
When water is heated, its volume initially decreases due to the unique structure of ice, which is less dense than liquid water. Ice has a density of approximately 0.9167 g/cm³ at 0 °C, making it about 8.3% less dense than liquid water, which reaches its maximum density of around 1.00 g/cm³ at 4 °C. As heat is applied, the crystalline structure of ice breaks down, causing the water to occupy less space until it reaches a certain temperature. Once the water is heated beyond this point, it begins to expand again as it transitions to steam, which occupies significantly more volume. This behavior is attributed to hydrogen bonding, which influences the packing of water molecules and their density at different temperatures.
mia5
Why is that when water is heated it's volume first decreases and then increases ?
Chemistry news on Phys.org
the theory goes that water as ice the molecules are more widely separated and then as the crystal shape is destroyed by the added heat the water becomes liquid and takes up less space and then when its hot enough it will transition to steam taking up a lot more space.
Wikipedia describes it better:
An unusual property of ice frozen at atmospheric pressure is that the solid is approximately 8.3% less dense than liquid water. The density of ice is 0.9167 g/cm3 at 0 °C,[2] whereas water has a density of 0.9998 g/cm³ at the same temperature. Liquid water is densest, essentially 1.00 g/cm³, at 4 °C and becomes less dense as the water molecules begin to form the hexagonal crystals[3] of ice as the freezing point is reached. This is due to hydrogen bonding dominating the intermolecular forces, which results in a packing of molecules less compact in the solid. Density of ice increases slightly with decreasing temperature and has a value of 0.9340 g/cm³ at −180 °C (93 K).[4]
refer to: http://en.wikipedia.org/wiki/Ice
thanks
Thanks for the answer :)
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
