Polytropic Equation: Is Temperature Constant?
  • Thread starter Thread starter jaredokie
    Polytropic
In a polytropic thermodynamic process, temperature is not constant, despite the equation pv^n=c suggesting a relationship between pressure and volume at different states. This equation is derived from the analysis of gas experiments, but it does not imply isothermal or adiabatic conditions. Instead, it applies to quasistatic processes involving simple compressible gas systems, where heat transfer is not negligible. The equation allows for various values of n, with specific cases like n=1 for isothermal and n=γ for adiabatic processes. The term "polytropic" was introduced to describe these processes that adhere to the p-v relationship under controlled temperature conditions. The derivation of the equation itself remains unclear, prompting further inquiry into its origins.
jaredokie
Is temperature constant in a polytropic thermodynamic process? The equation pv^n=c leads me to believe so. But logic tells me otherwise. Its not isothermal or adiabatic. Did they derive this equation from using log transforms when analyzing gas experiments?
A polytropic process does not require the heat transfer to be negligible. The process is following a relationship between equilibrium states. The equation is restricted to a quasistatic process for a simple compressible gas system.
The above is taking from "Thermodynamics" 5th Edition by Wark. Page 664
But how did they come up with the equation pV^n=c?
I can find any derivation for that equation. I'm trying to understand how the equation was formed.
People noted that, for an isothermal process, n=1 and for an adiabatic process, n=γ. So they figured that, if the temperature is controlled properly, there can be other processes which satisfy a p-v equation of the specified mathematical form. They coined the term "polytropic" to refer to such processes.
