Applying kirchoff's current law on transistor considering it a single
Applying Kirchhoff's Current Law (KCL) to a transistor involves understanding that it acts as a single node where the net current is the sum of charge carriers moving in one direction. Transistors do not function as sources or sinks for electrons; instead, they facilitate the combination of holes (positive charge) and electrons (negative charge) at the junction in a 1:1 ratio. This results in a net current that flows consistently in one direction, either from holes to electrons or vice versa. The discussion emphasizes that despite the complexity of charge movement, KCL principles still apply. Overall, the behavior of charge carriers in a transistor aligns with KCL, reinforcing the concept of current conservation.
Phyman1109
How can I apply kcl on transistor considering it as a single node since transistor can act as source or sink for electrons due to combination with holes
Well current in = current out ... always...
A Transistor is NOT a source or sink for electrons - at the Junction holes ( + charge ) combine with electrons (- Charge) and the ratio is 1:1 - always... so net current is charge moving in a single direction.
Consider Holes + charge moving ---> (left to right) to the junction compared with Electrons moving <---- to the junction ( right to left ) ... the net current ( think charge x direction) is all moving the same direction.
Oh...thanks.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
