Why is there a higher peak at resonance frequency?
The discussion centers on the phenomenon of a higher peak at resonance frequency in an RLC circuit as observed through a spectrum analyzer. The increased peak is attributed to the phase relationship between voltage and current, which changes at resonance, allowing for maximum power transfer from the generator to the circuit. The conversation highlights that away from resonance, the average power dissipated is lower due to phase misalignment, while at resonance, the energy transfer is optimized. Additionally, the importance of the measurement setup is emphasized, including the need for proper impedance matching and the effects of cable lengths on the observed response. Understanding these factors is crucial for accurate analysis of the circuit's behavior at different frequencies.
Bromio
Hi.
When using spectrum analyzer to measure the response of a coil (a RLC circuit), I see that there is a peak at one frequency (resonance frequency). This is logical because we can model a coil as a RLC circuit. If I change the frequency of the sinusoidal source, the peak reduces its value.
My question is: why is there a higher peak at resonance frequency? If what I measure is the power dissipated (by the resistor, of course), why is there a dependence with frequency?
If complex power is written as P = P_{loss}+2j\omega\left(W_m-W_e\right), where P_{loss} = \frac{1}{2}\left|I\right|^2R is the dissipated power, W_e is the electric energy stored in the capacitor and W_m is the magnetic energy stored in the inductor, why the analyzer doesn't show a constant peak value (given by P_{loss}) whatever the frequency of the sinusoidal source?
Thank you.
I would guess that the driver power reaches its maximum at the resonance frequency, but it is hard to tell if you don't show the setup and explain where you measure what.
I rolled two wires around the coil: one coming from the sinusoidal signal generator and another one going to the spectrum analyzer, which also showed "power" (dissipated power, I suppose).
So, I was measuring the voltage drop in the coil (which can be modeled as a RLC circuit). Sweeping frequencies I noted there was a higher peak at resonance frequency.
Thanks.
mfb said:
I would guess that the driver power reaches its maximum at the resonance frequency.
That's the reason, but I agree that what happens can seem like a paradox at first sight.
If the driving frequency is constant, then once the starting transient has decayed the power dissipated in the resistor is (obviously) the same as the power supplied by the signal generator.
The phase angle between the the generator voltage and current changes as you go through the resonant frequency. That is why the power (in watts) from the generator is not necessarily the same as the volt-amps it is producing.
Maybe this is easier to see with a mechanical oscillator like a mass on a spring. If you apply a force an a frequency much lower than resonance, you can ignore the inertia of the mass. The applied force is in phase with the motion, so the positive work you do compressing the spring is equal to the negative work done by the spring when you release it.
At a frequency much higher than resonance, you can ignore the force in the spring compared with the inertia force needed to accelerate the mass. The displacement is now 180 degrees out of phase with the force, but the effect is the same: the work you do on the mass averages out to zero, over a complete cycle.
Away from resonance, a plot of work done against time may have large positive and negative amplitudes in each cycle (analogous to measuring volt-amps) even though the average work done over the cycle is low (analogous to measuring watts).
But when you are at the resonant frequency, the displacements are 90 degree out of phase with the force, and you do work on the system over the complete cycle. And of course as the amplitude increases, a constant force does even more work, because the product of force x distance increases.
Bromio said:
Hi.
I think you need to supply more detail on your measurement setup. Are you using spectrum analyzer tracking gen for source? If not what is the source, 50 ohms? How is inductor connected to 50 ohm input to spectrum analyzer and the source, coaxial cable? Are you doing anything to match your inductor to 50 ohms (i.e. broadband attenuator)?
To give you an idea where I am going with this, if you are using coax to extend source & spectrum analyzer down to your inductor, you will see periodic dips in response due the the cable lengths.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
