Penetration of X Rays in body tissue
Radiotherapy involves complex interactions of X-rays with body tissues, where the maximum dose is not at the surface but at specific depths, such as 0.4cm for 2MV photons and 2.3cm for 10MV photons. This phenomenon occurs because the energy loss of photons is not exponential; instead, it is proportional to 1/E, leading to most energy deposition near the end of their track. The continuous energy loss results from interactions with electrons in the tissue, causing ionization to peak at certain depths before declining. The Bragg Peak concept is crucial for understanding this non-linear behavior, as it allows for maximizing ionization at targeted depths while minimizing damage to surrounding tissues. This understanding is essential for optimizing radiotherapy techniques.
sophiecentaur
I have been looking for information about the way Radiotherapy works and, needless to say, there is much more involved than just local frying of tissue. I have been told and also read, that the dose received in tissue is not necessarily maximum at the surface. For instance, the dose seems to be a maximum at 0.4cm for 2MV photons and 2.3cm for 10MV photons. I cannot think why, if the absorption is exponential with depth (or so I would expect) the maximum effect (energy from the beam) is not right at the surface. 2.3cms is very deep under the surface. What happens between the surface and that depth to make the dose less?
I have looked in all the places on the web that I can think of but, as usual, what's available is either the chatty home-medecine advice or the latest papers which all assume the reader knows this sort of basic thing. Any ideas? I think this is probably the right forum as it's basically Physics.
For the photon energies used, the rate of energy loss dE/dx is approximately proportional to 1/E. This means they deposit most of their energy near the end of their track. It is not an exponential attenuation like scattering where a single scattering event causes a photon to lose all of its energy and to be lost from the beam. There is continuous energy loss along the track due to the interaction of the photons with the electrons in the matter, and this energy loss increases as the photon loses energy, so most of the energy gets deposited at the end of the track.
Great answer. Makes perfect sense. Thanks a lot.
Does that work for photons?
They ionize along their path and the buildup of ionization peaks at a certain depth and then falls exponentially. For that reason, several beams of ionization beams are to used to obtain a maximum of ionization at a certain depth, and lessen tissue damage ouside the peak.
256bits said:
Ah yes, the Bragg Peak! It's only taken 110 years since it's invention for me to have taken it on board! We are not dealing with a linear system here and, as a Radio Engineer, I didn't take that into account.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
