Software for atomic orbitals oveplap in molecules
The discussion centers on the need for interactive software that visualizes the overlap of hybridized atomic orbitals in molecules, rather than molecular orbitals. It clarifies that hybridized orbitals are not part of molecular orbital theory but are derived from atomic orbitals, emphasizing the importance of valence bond theory for accurate hybrid orbital representation. Participants express interest in the overlap of chlorine's 3d orbitals with oxygen's 2p orbitals in various chlorate ions, questioning the significance of chlorine's d-orbitals in bonding. The conversation highlights that the shapes of orbitals dictate overlap and that chlorine's d-orbitals are generally not crucial in main group compounds. Overall, the need for visual representations and the distinction between orbital theories are key points of the discussion.
sludger13
I would be most grateful for some tips of interactive software, which shows the hybridized atomic orbitals overlapping in the molecule (I don't mean resulting molecular orbitals but atomic orbitals of which overlapping forms MO).
And does this works also in Mathematica?
Chemistry news on Phys.org
You are mixing up something here. Hybridized orbitals aren't a concept of MO theory, i.e., molecular orbitals are not built up from hybrid orbitals but directly from atomic orbitals.
If you want to get best hybrid orbitals you have to use valence bond software and among those there are not many programs which do the hybrid optimization. The Spin coupled valence bond program by Gerratt, Cooper and Karadakov comes to my mind. You would have to contact this group to get access.
But the orbital overlap is dictated by the shape of orbitals, as I laically deduce. E.g. the exchange interaction as a measure of overlap could depend upon atom hybridization, isn't it true?
I'm curious how chlorine's (3d) orbitals and oxygen's (2p) orbitals are ovelapping in space, so that every (sp2) oxygen participate in delocalized orbital in (ClO2-, ClO3-, ClO4-). I would be satisfied just with a single picture, however I haven't found any.
Sure, but this is valence bond theory, not MO theory.
Chlorines d-orbitals are unimportant for bonding. This is true in all main group element compounds, not only chlorine.
See, e.g.,
Reed, Alan E., and Paul V. R. Schleyer. "Chemical bonding in hypervalent molecules. The dominance of ionic bonding and negative hyperconjugation over d-orbital participation." Journal of the American Chemical Society 112.4 (1990): 1434-1445.
Ok, so the overlap is "nothing special" due to inefficient orbital's shapes. But what are their shapes? As the orbitals might be unhybridized, could I imagine "standard" atomic ((p) and one/two/three (d)) orbitals overlapping (just a little :))?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
