Single supply preamp and active crossover
  • Thread starter Thread starter Tesladude
    Supply
The discussion focuses on designing a single supply preamp and active crossover using the LM833N dual op-amp for car audio applications. The user has successfully implemented a single supply preamp circuit based on a voltage divider and capacitor but seeks clarity on adapting the crossover circuit. They reference the high pass crossover design from the datasheet but are unsure how to configure it for single supply use. Other participants suggest that the crossover circuit should resemble the single supply op-amp circuit with specific connections for the input impedance and output capacitor. Overall, the conversation highlights the need for more detailed circuit diagrams and specific configurations to ensure proper functionality.
Tesladude
Hi I am making a preamp and active crossover using the lm833n dual op-amp.
I have already done a project similar to this one and both the preamp circuit and crossover circuit worked beutifuly,
although that project used a split supply and for my car audio I need a single supply.
I have already tried a single supply preamp circuit useing just the basic single supply opp amp circuit which consists of the voltage divider with a capacitor across the grounded resistor, just like the single supply circuits you can find on the tda2040 or tda2050 datasheets.
It worked fine.
I am using the high pass crossover circuit design from the datasheet.
But I am not 100% sure on how the crossover single supply circuit ia sopposed to look.
I figure it is essencially the same as the single supply op amp circuit with the imput impedence resistor connected strait to the center of the voltage divider and with a capacitor on the output.
is it the same?
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
i think you have the right idea, but your description is so vague I'm afraid to say much.
it is not clear to me which of the active crossover circuits you want to use - the TDA2040 shows bridged woofer and single tweeter. For single amplifier on single supply you need to feed the speaker through a large capacitor.
Maybe you'd post a link to the circuit you want to adapt for single supply ?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
