Tracing a laser pointer with IR camera
It is possible to trace a laser moving over a surface like a wooden floor using an IR camera, provided the laser operates at a frequency detectable by the camera. The camera can capture the light scattered from the floor, similar to how visible light is perceived. However, the duration for which the trace can be detected after the laser moves is minimal, as the only way to observe a lingering trace would be if the laser heated the surface enough to continue glowing in the infrared. Such powerful lasers are typically not safe for general use and are more akin to cutting tools or weapons. Therefore, for tracking purposes, a less intense laser would be necessary.
MarcGyongyosi
Hi!
a very basic question that probably has a simple answer: would it be possible to trace a laser moving over a generic surface such as a wooden floor with an IR camera?
The idea would be to calculate relative movement based on that...
If I'm not clear enough feel free to follow up with a question!
Thanks!
Marc
edit: maybe I should add that it would be preferred if the laser was in the invisible part of the spectrum and also safe for use around humans.
Science news on Phys.org
MarcGyongyosi said:
Hi!
Do you have a laser that operates at a frequency that your camera responds too? If so, the camera will "see" the light scattered from the floor in the same way that your eyes see the visible light from a laser pointer being used as a pointer.
Likes 1 person
Hi!
thanks for the quick answer! That's what I thought would happen! I was wondering, however, if there was any way to predict* for how long you could pick up the trace from the laser after it hit the ground - which would be essential for calculating relative movement...
*based on material properties
How long? Zero, near as no never mind. The only way you could detect observe points where the laser had been shining but no longer is would be if the laser light heated the surface sufficiently for it to continue to glow in the infrared after the laser had moved on.
A laser that powerful isn't a tracking device, it's a cutting tool or a weapon.
