Light propagates faster than the rate of expansion of the universe?
The discussion explores whether objects on opposite sides of the observable universe are moving away from each other faster than light, noting that while their distance can increase faster than light, they are not technically moving apart in a conventional sense. It raises the question of light emitted from a galaxy at the universe's edge and its ability to reach distant objects, suggesting that if the universe continues to expand, some light may never reach us. The conversation also addresses the concept of a finite universe, arguing that it can exist without an edge, similar to the surface of a sphere. Participants clarify that the universe may be curved and closed without requiring a fourth dimension, and current observations indicate it is close to flat. The debate concludes with the acknowledgment that the universe could be vast enough that any curvature remains undetected within measurement errors.
iDimension
I know the universe doesn't expand at a speed but rather a rate over distance but if we take two objects on opposite sides of the observable universe, would they be moving away from each other at a greater rate than light?
IE if object A was a star and object B was a planet, would the light from the star still be able to reach the planet or would they be moving away from each other faster than light can catch up?
And that got me thinking, what if the univere is finite and a galaxy on the "edge" of the universe were to emit light, that light would travel away from the galaxy but only at some point there literally wouldn't be anymore universe for the light to travel into so what happens?
To me at least everything we know about the universe (which isn't very much to be honest) but enough for me to think that an infinite universe just makes so much more sense than a finite one. Isn't it much more likely that the universe is infinite because if the universe is everything that exists then it must, by it's own definition, be unbounded and infinite?
Astronomy news on Phys.org
Yes and no. Their distance increases faster than the speed of light, but they are not actually moving away from each other.
That depends on the evolution of the expansion rate over time. In general, it can be possible - we now see things where the distance increases faster than the speed of light, but if the expansion keeps accelerating, then there are things we will never see.
A finite universe does not have to have an edge - it could be shaped like the surface (!) of earth, for example. Finite, but without an edge. I'm not aware of any reasonable model with an actual edge that could somehow be reached.
No.
The problem I have with this view though is sure the Earth doesn't have a 2D edge but it does have a 3D edge... straight up and you will come away from the surface of Earth but space is like a "sphere" in all directions otherwise if you traveled "up" you'd eventually look down and see the universe which as far as we know that wouldn't happen.
Unless our universe really is like a sphere but it's SO stupendously large that our instruments cannot measure the curavture because it's so faint.
Can someone clear up my last post please as I still don't fully understand the concept of spherical universe.
Universe is not a sphere. The thing about analogies, is that they're never exactly the same as the thing they descibe.
When we point out to the surface of a sphere(e.g. Earth) being an example of a finite space(2-dimensional) without an edge(in those two dimensions that comprise the space), we do so because it's easy for a human mind to picture the sphere thanks to us being spatially 3-dimensional beings.
We use our imagination to embed the 2d surface in the 3d space we're familiar with, but such embedding is not mathematically necessary. That is, there is nothing mathematically speaking, preventing you from having a curved, closed 2d surface without the 3rd dimension at all.
All you need to make sure, is that any two locally parallel lines will eventually intersect, and angles in triangles add up to something more than 180°.
Similarly, with our universe being spatially 3-dimensional as it is, it can have curvature without there being a fourth dimension to be embedded in. All you need to have, is parallel lines intersecting and the triangles thing.
And indeed, if our universe were to be closed, we could look in one direction to eventually see the backs of our heads - at least in principle. But so far all observations suggest that the universe is remarkably close to flat. There's always the possibility of the universe being simply very, very large, so that any curvature is simply hidden in our error bars. The last time I checked(was a while ago), data from WMAP pushed the minimum curvature radius(remember, in the fourth spatial dimension, - which might not physically exist, but is useful as a descriptive tool) to 130-ish billion light years.
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
Asteroid, Data - 1.2% risk of an impact on December 22, 2032. The estimated diameter is 55 m and an impact would likely release an energy of 8 megatons of TNT equivalent, although these numbers have a large uncertainty - it could also be 1 or 100 megatons. Currently the object has level 3 on the Torino scale, the second-highest ever (after Apophis) and only the third object to exceed level 1. Most likely it will miss, and if it hits then most likely it'll hit an ocean and be harmless, but...
