Water Cooled PC and Condensation
In a discussion about water-cooled PCs and condensation, the key concern is how cold the water can get before condensation forms on cooling blocks. The onset of condensation is influenced by the room's humidity and the dew point, which is typically around 40°F with a properly sized air conditioner. Insulation and sealing of cooling components are crucial to prevent condensation, especially if the cooling water approaches freezing temperatures. Users are advised to utilize tools like a psychrometric chart and humidistat to monitor dew points effectively. Proper insulation techniques, similar to those used in extreme cooling setups, are recommended to mitigate condensation risks.
Jobistober
Hello all,
I have a water cooled PC and am about to install a thermoelectric cooling device which can easily cool the water to near freezing temperatures. The cooling blocks are manufactured from copper and acrylic, and the hose is just a generic plastic hose. here's my question: how cold can the water make the blocks before condensation starts? I know that water will condense onto surfaces way before freezing. If anyone knows a definite answer or a way to find it, please drop a line. Thanks.
Well, it depends on the humidity of the air in the room where the computer is located. The simple answer is that a correctly sized air conditioner makes for a dew point of around 40F, so water below 40F will cause condensation on the tubes if they are not well insulated and sealed. But if the air conditioner is not well sized or not on all the time, the humidity can vary widely. Use a psychrometric chart and a humidistat to find the dew point. Better yet - insulate and seal anything that may get cold.
It depends on what the dew point is which is dependant on the humidity. What most people do when they are worried about condensation occurring is to insulate the CPU block.
http://www.tomshardware.com/cpu/20031230/5ghz-07.html
One guy used LN to cool his CPU and he used this little thing to pour the CPU in and it was wrapped in an insulating material. Although that's nothing like what you would do, the material is probably something you'd be looking into to insulate the CPU.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
