Electric Field of an n sided polygon
lao
We have an n sided polygon, each side is length 2L and R is the distance from the center of the polygon to the mid-point of any side. We know, L=Rtan(pi/n).
I need: "the E-field on the axis of the polygon at a point distance h above it"
When n goes to infinity, we should get the same E-field as a uniform ring charge:
E= kQh/(h^2+R^2)^1.5
any help would be awesome, thanks :)
And, what have you done so far to solve the problem?
Simple: do we have any symmetry here? Find the field to a single side (a finite line segment).
Hope this helps.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
