9v Batteries Powering Multiple Items
  • Thread starter Thread starter alimagator
    Batteries Multiple
The discussion revolves around wiring ten flickering candles powered by 9v batteries into a system that allows easy battery replacement and a switch for on/off functionality. The user initially achieved success with the setup but encountered rapid power drainage and flickering after replacing the batteries, despite using new ones. Suggestions include checking the wiring for potential issues, particularly the internal resistance of batteries in parallel, which could affect performance. An alternative recommendation is to consider using button battery candles, which offer longer runtimes and simpler operation. The user is seeking solutions to ensure consistent performance across all candles.
alimagator
I'll start with the typical "I'm new to this and don't know much about DC wiring and power." I'm trying to wire 10 flickering candles that each run on a single 9v battery into a fake cake and do so in a manner that will make pulling the batteries out quick and easy without having to remove each individually, and have it all part of a system that can be turned on and off via a switch. From what I was reading I figured I'd be able to create a container that I could insert 10 9v batteries into and have that wire into each candle through a parallel wiring scheme to increase the power output while keeping the voltage the same. This unit only needs to power the candles for about 15 minutes at a time, and a new 9v will power a single candle for about 80-90 minutes from our tests. Once I had completed this project everything seemed to work fine for the 3-4 we ran it using the same set of batteries but then I started running into problems after the initial set was replaced. The candles arent staying lit very long and seem to be draining power very quickly causing the candles to fade rapidly and be out completely out in a matter of minutes. The voltage seems to be dropping rapidly when I meter run a meter through it, and this is happening with entirely new sets of batteries. Anybody have any explanations or suggestions as to what may be happening here and how to fix it? I wouldn't be that surprised if this just didnt work from the start, but I am baffled by how it worked fine until we started changing the batteries.
So a single battery will power a single candle for 90 minutes, but ten batteries only power ten candles for 3-4?
Perhaps you could draw out how you've wired the system up?
If you are wiring batteries in parallel, internal resistance of one (bad/used) will sink power from the others.
Other than the 'single switch' aspect, I suspect that you might be farther ahead to just buy the 'button battery' artificial candles. My wife sells them for a couple of dollars each at her 'cheap' store, and they're good for more than 12 hours. There's just a simple twist cap on the bottom to turn them on and off.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
