How Does Energy Compensation Occur in Amplifier Systems?
  • Thread starter Thread starter japam
    Amplifiers
Energy compensation in amplifier systems involves the relationship between input signals and the power supplied by the amplifier. When a small electromagnetic signal is amplified, the energy increase must be balanced by energy drawn from the power supply, primarily through the transistors. The amplifier's design limits its power output based on the load it drives, with typical speaker impedances ranging from 2 to 8 ohms. As load changes, the current and voltage across the transistors also vary, impacting performance and potentially leading to failure if limits are exceeded. Ultimately, amplifiers serve as voltage-increasing devices that rely on a stable power reserve to manage signal amplification effectively.
japam
well i have this simple question, its about the energy in a amplifier system, whatever class is it, you have at first a tiny electromagnetical signal in the space with an amplifier system with its resistances, condensers, transitors,coils, calculated to work on certain constant voltages and currents with stability.
and then after the signal passes through the amplifier its boosted, so you have the same energy in the amplifier, because its stability of polarization and aggregate the power boost of the signal, so there's an increasing of the energy in the total system signal-amplifier
so my question is: this grow in energy has to be compensated by a decay of energy in the amplifier? , where exactly, in the transistor?
You are using energy from the power supply to boost the energy in the signal. The transistors are the amplifying elements, but the power gain comes from the power supply.
then any amplifier must have a limited power for load , because the transistor is designed to just work on certain voltage-current range,
and that means also that the current-voltage changes in the transistor according to load or not load in the output , with the same power source ,right?
A transistor will indeed behave quite differently when different loads are presented to it. Most audio power amplifiers, for example, are designed to drive speaker loads, which are typically in the range of 2 to 4 ohms.
- Warren
Minor correction Warren, most speakers for home use would be a nominal 8 ohms and 4 ohms for car use. Although in some car subwoofers, the 2 and 1 ohm impedance exists for the loudly motivated. In the pro audio world, 16 ohm and 24 ohm drivers exist too, and then there are public address speakers that sometimes have an autoformer (transformer) to work on 70.7V systems.
Japam - think of the amplifier as a voltage increasing device. If a 2V signal is fed into it, and it has a gain of 20 then it will output a voltage of 40V.
Since we know that E^2/R = W then 400/8 = 50W, 400/4 = 100W and so on. At some point, the current will exceed what the amplifiers power supply can handle and at that point the power will drop off because it is not able to handle that load very well (if at all). Or if the impedance were to go too low, its possible the transistors will attempt to pass more current than they can handle and burn out.
Boost isn't really the most handy way to think of it in my opinion, its more a frame of reference.
Maybe a more handy way to think of it would be that you have a big power reserve waiting to do something and a small signal voltage that controls the power delivery. Kind of like how a car engine makes a lot more power than your leg could, but your leg controls it with the accelerator pedal.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
