A Bessel's functions of the second kind (Neumann' functions) deduction
  • Thread starter Thread starter Rulonegger
    Functions Neumann
Rulonegger
I need to obtain the Bessel functions of the second kind, from the expressions of the Bessel functions of the first kind.
Laplace equation in circular cylindrical coordinates reads
\nabla^2\phi(\rho,\varphi,z)=0 with \nabla^2=\frac{1}{\rho}\frac{\partial}{\partial \rho}\left(\rho \frac{\partial}{\partial \rho} \right)+\frac{1}{\rho^2}\frac{\partial^2}{\partial \varphi^2}+\frac{\partial^2}{\partial z^2}
Supposing that \phi(\rho,\varphi,z)=R(\rho)\Phi(\varphi)Z(z) i get \begin{eqnarray} Z_{m}(z)=A_{1_m}e^{m z}+A_{2_m}e^{-m z} && && \Phi_{k}(\varphi)=A_{3_k}\cos{k \varphi}+A_{4_k}\sin{k\varphi} \end{eqnarray} with m and k being the eigenvalues from the ODE's associated with Z and \Phi, respectively.
Then the associated ODE for the radial component is \frac{d^2R}{d(k\rho)^2}+\frac{1}{k\rho}\frac{dR}{d(k\rho)}+\left(1-\frac{m^2}{(k\rho)^2}\right)R=0 and defining x=k\rho i get \frac{d^2R}{d x^2}+\frac{1}{x}\frac{dR}{d x}+\left(1-\frac{m^2}{x^2}\right)R=0 which is Bessel's differential equation. Using Frobenius method to remove the singularity, I'm able to compute Bessel functions of the first kind J_{m}(x)=\sum_{s=0}^{\infty}{\frac{(-1)^s}{s!(m+s)!}\left(\frac{x}{2}\right)^{m+2s}} for m integer. Changing n by -n and removing the zero terms in the series for J_{-m}(x), we see that
J_{-m}(x)=(-1)^{m}J_{m}(x) so both functions are linearly dependent, and we need to specify another function of x linearly independent of J_{m}(x) because the differential equation is a second order one.
Then, a common way to find a second function of a differential equation of the form y''(x)+p(x)y'(x)+q(x)y(x)=0 with a known solution y_{1}(x), we can suppose that y_{2}(x)=y_{1}(x)g(x). After deriving y_{2} and substituting in the differential equation, we get
\frac{g''}{g'}=-\frac{y_{1}'}{y_{1}}-p
but if i try to use this method to find the Neumann's functions Y_{m}(x), i cannot find the expression
Y_{m}(x)=\frac{\cos{mx}J_{m}(x)-J_{-m}(x)}{\sin{mx}} which commonly one finds that it is a "definition" for the Neumann's functions. Any ideas?
Correction
I'm sorry, but the last expression was Y_{m}(x)=\frac{\cos{m\pi}J_{m}(x)-J_{-m}(x)}{\sin{m\pi}} Any kind of help would be greatly appreciated!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
