A confusing trigonometric question
The discussion revolves around a trigonometric equation presented without clear parentheses, leading to confusion about its validity. The equation in question is sec x + csc x / tan x + cot x = sin x + cos x, which, when interpreted without parentheses, does not hold true. The correct interpretation, (sec x + csc x) / (tan x + cot x) = sin x + cos x, is identified as an identity that can be proven. The participants emphasize the importance of proper notation in mathematical expressions to avoid misinterpretation. Ultimately, the original equation lacks a solution, highlighting the significance of clarity in mathematical communication.
Hells_Kitchen
A confusing trigonometric question!
Hi guys, I had a question. I was given the following equality. There was no problem statement that came with it (i.e. it did not say solve the equation or prove the identity, or anything of this nature)
The person that handed it to me said that he solved it whatever that means. Now, if this was an identity (i.e. true for all permissible values of x) than it should be true for say x=45 degrees. Clearly it is not!
Then I considered it as an equation (i.e. true for SOME permissible values of x). I studied the function f(x) = LHS - RHS and I saw that this function does not attain the value 0. So even as an equation, there is no solution.
Am I doing something wrong here, or is the other person doing something wrong?
Thanks guys!
Please, please, please use paretheses to make yourself clear! I assume you actually mean (sec x + csc x )/ (tan x + cot x) = sin x + cos x. What you wrote would, using the standard rules of algebra, be sec x + (csc x / tan x)+ cot x = sin x + cos x
but that is clearly not true.
My general rule, not always the simplest, is to start by replacing all functions by sine and cosine. Here, you have, on the left,
\frac{\frac{1}{cos x}+ \frac{1}{sin x}}{\frac{sin x}{cos x}+ \frac{cos x}{sin x}}.
Now multiply both numerator and denominator by of the main fraction by sin x cos x.
hmmm. Someone who is taking algebra gave me this equation and the way he had written it was exactly this:
He could not solve it for some reason, but this equation cannot be solved as it is written.
On the other hand, (sec x + csc x )/ (tan x + cot x) = sin x + cos x is an identity which is easily proved as you suggested above. I was arguing with him and I was telling him that he must have copied the problem wrong. So I see that he forgot parantheses which turned an easy problem into a nightmare.
ok then, sorry about the hassle. Thanks for the quick response. But I did mean the equation without parantheses because that equation does not have a solution if you try to solve it!
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
