A container holds 8.0kg of water at 25degC....
  • Thread starter Thread starter MaryBarnes
    Container Water
To determine the energy required to convert 8.0 kg of water at 25°C to 2.0 kg of steam, the relevant formulas for heating and phase change must be used. The total energy calculation involves both the specific heat capacity of water and the latent heat of vaporization. The formula applied is Q total = mcwΔt + msLf, where Q total represents the total energy, m is mass, c is specific heat, Δt is the temperature change, and Lf is the latent heat. The calculated energy amounts to approximately 7.12 million joules. Including all units in the calculations is essential for clarity and accuracy.
MaryBarnes
how much energy must be added to the water to create 2.0 kg of steam?
I have no idea how I am supposed to figure the answer out. what formulas do I use?
What formula do you know that is related to heating and/or transforming material from one physical state to another? Those are the two processes which must occur here.
q=mLv
i attempted the answer:
Q total=mcwΔt+msLf
=8.0kg*4200j/kg*(100°C-25°C)+2.0kg*2.3*106
=7.12*106J
Q total=mcwΔt+msLf
=7.12*106J
Yes.
If you want to make your working letter-perfect, include all units: 8.0kg*4200J/kg/°C*(100°C-25°C)+2.0kg*2.3*106J/kg.
haruspex said:
Yes.
awesome! thanks for the help!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
