How Does a Faulty Model Rocket's Motion Change Over Time?
A faulty model rocket experiences motion in the xy-plane with specific acceleration components defined by a quadratic function in the x-direction and a linear function in the y-direction. The initial conditions include a starting position at the origin and an initial velocity of 1.00 m/s in the x-direction and 7.00 m/s in the y-direction. To determine the velocity vector as a function of time, users are instructed to express it in terms of the given parameters. Similarly, the position vector must be calculated and expressed in a specified format. The discussion emphasizes the straightforward nature of deriving velocity from the provided acceleration.
mohd22
1. A faulty model rocket moves in the xy-plane (the positive y-direction is vertically upward). The rocket's acceleration has components a_{x}(t)= \alpha t^{2} and a_{y}(t)= \beta - \gamma t, where \alpha = 2.50 {\rm m}/{\rm s}^{4}, \beta = 9.00 {\rm m}/{\rm s}^{2}, and \gamma = 1.40 {\rm m}/{\rm s}^{3} . At t = 0 the rocket is at the origin and has velocity {\vec{v}}_{0} = {v}_{0x} \hat{ i } + v_{0y} \hat{ j } with v_{0x} = 1.00 {\rm m}/{\rm s} and v_{0y} = 7.00 {\rm m}/{\rm s} .
2. Calculate the velocity vector as a function of time.
Express your answer in terms of v_0x, v_0y, beta, gamma, and alpha. Write the vector \vec{v}(t) in the form v(t)_x, v(t)_y, where the x and y components are separated by a comma.
Calculate the position vector as a function of time.
Express your answer in terms of v_0x, v_0y, beta, gamma, and alpha. Write the vector r(t)_vec in the form r(t)_x, r(t)_y where the x and y components are separated by a comma
Your answer should be an expression, not an equation.
Since your post contains LaTeX code, you might find the [ tex] and [ itex] tags useful (without the space), like so:
a_{x}(t)= \alpha t^{2} (display mode for use on separate line)
a_{x}(t)= \alpha t^{2} (text mode for inline use)
- you can click on them to see the code.
As for your question, you are given the acceleration and asked the velocity. That seems rather straightforward to me. What did you try already?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
