A Integration Problem[Indefinite Integral]
The discussion revolves around evaluating the integral ∫ (x sin(x²)) / cos³(x²) dx. The initial approach involved a substitution of t = x², but confusion arose regarding how to proceed after that. Participants suggested alternative substitutions and emphasized the importance of differentiating the final answer to verify correctness. Clarifications were made about the substitution process, particularly how to handle the relationships between x, dx, and t. Ultimately, the conversation highlights the integral's complexity and the necessity of careful substitution to arrive at the correct solution.
Hysteria X
Evaluate
<br /> \int (x sin ( x^2 ) )/cos^3 ( x^2 ) dx<br />
none the i know that would be helpful here
I tried solving this by substitution method by substituting <br /> t = x^2 as t but i don't know how to proceed after that :confused:
Hysteria X said:
Evaluate
Show us what you got, because you should be able to push that through. Alternatively, try ##t=\cos(x^2)##.
Damn how could i not see that :rolleyes:
okay i got the answer as ##I= 1/4(1/cos^2(x^2)## :biggrin:
Can anyone confirm this :rolleyes:
You don't need someone else to confirm it. Differentiate your answer and see if it works.
Don't forget the constant of integration.
If you had gone with your first idea, t= x^2 so that dt= 2x dx and (1/2)dt= x dx, you would have got (1/2)\int sin(t)/cos^3(t) dt. Now, it should be clear, with that "sin(t)dt" in the numerator, you can let y= cos(t), so that dy= sin(t) dt, and the integral becomes (1/2)\int dy/y^3= (1/2)\int y^{-3}dy.
Essentially, you are doing the same thing in two steps rather than one.
Sir correct me if i am wrong but i think there is a mistake in the method you have done which i first stated.
if we took t= x^2 and dt =2x dx we cannot substitute that in the equation because ##x^2## is within the sine function and dx is outside? :confused:
Wait wait wait. Listen to what you're saying here. You said t = x2 right? So everywhere x2 appears in your equation you replace it with t.
Now dt = 2x dx which implies that (1/2)dt = xdx. So anywhere you see xdx ( which it's VERY apparent to see ), you replace it with (1/2)dt.
Clear now?
You replace all occurrences of x separately.
So the sine and cosine contain an x², which you substitute by t.
Then outside the trig functions, you are left with an x dx which - as you said - you substitute by (1/2) dt.
  • · Replies 22 ·
  • · Replies 105 ·
  • · Replies 22 ·
