A interesting phenomenon about fingerprints and liquids
The discussion centers on the phenomenon of total internal reflection (TIR) observed when viewing fingerprints through a glass of water. When fingers touch the glass, the damp surfaces disrupt TIR due to similar refractive indices of glass and water, allowing the patterns to be seen. At steep angles, the glass appears shiny, while bubbles also reflect light due to TIR. Additionally, refraction bends light entering from the side, making it difficult to see through the water unless viewed from a low angle. This explanation clarifies why certain materials behave differently when viewed through a glass of water.
hchs9818
Hello,I just discover a interesting phenomenon at lunch time when I drink a glass of water:
When I hold a glass in my hands, If I look from above at the innerwalls of the glass, we can see a very bright and clear image of patterns on your fingertips through the glass. But when I use other meterials, we can only see the innerwalls of the glass from the top of the glass, but can't see the material.
How do the phenomenon happens? I wonder it is because of the total reflection.
I'm very eager to understand it!
Thank you very much!
With best regards,
Julia
Welcome.
Yes, it is a TIR thing.
TIR works at quite steep angles for glass into air - hence the inside possibly looks shiny or you see the bottom of the glass perhaps. This is also why bubbles look shiny. When your fingers (with slightly damp surfaces) touch the glass, TIR no longer happens at that angle because the two media (glass and water) have similar refractive indices (relates to densities). You see only what comes through the glass and not the internal reflection. It will only happen at very oblique angles. OH yes - why don't you see through to the outside of the glass through the surface of the water? Refraction causes the light coming in from the side to be bent' downwards' to below the lip of the glass. If you put your head very low (almost sideways), you can actually see some objects on the table through the water. (I just went out to the kitchen to confirm this - how sad am I?)
If you put damp cloth against the glass you will probably see the fibres but not when it's dry.
Enjoy your next drink.
Thanks you very much!
That really helps, I'm very appreciate about it!
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
