How Do You Solve a Modified Atwood Machine Problem?
  • Thread starter Thread starter kindor
    Atwood
To solve a modified Atwood machine problem involving masses m2 and m3, first determine the normal force and friction for each block. Next, modify the Atwood's equation to account for the incline and calculate the acceleration. Use kinematics equations to find the time it takes for each mass to reach the ground. Finally, subtract the time taken by m2 from that of m3 to find the time difference. This approach will also help in determining the landing spots of the two masses.
kindor
What the time difference between the instance that m2 and m3 hit the floor?
How far are their landing spots?
So far I have figured out the normal force of the two blocks each, and then I found the friction of them both.Here is my work so far and the question. I have no clue on what to do next.
http://imgur.com/YRnxb
It's an Atwood's machine, so you should be able to modify the Atwood's equation for acceleration to fit the specifications for an incline, and then solve for acceleration. From there, I'm assuming you would use kinematics equations to solve for the time it takes for each block to travel the distance to the ground, and then subtract the time for mass 2 from mass 3 to solve for the time difference.
