A phenomena i cant fully understnad
  • Thread starter Thread starter alexay95
    Phenomena
The discussion centers on the behavior of a screw when rotated at different speeds, noting that low-speed rotation leads to a stop, while high-speed rotation causes it to rotate backward before stopping. Participants suggest that this may be due to drag forces with different effects at varying speeds, or the screw's interaction with its threads. The idea of the screw acting like a spring or a rattleback is debated, with some arguing that the screw's design allows it to roll on its threads when spun quickly. Others propose that the phenomenon could be related to the screw's length and the torque involved in driving it into hard materials. A video demonstration is recommended to clarify the observed behavior.
alexay95
when i rotate a screw at low speed he stop after sec.
but when giving him high initial speed he rotate,stop,and rotate backwards and stop again.
i think its because the drag force which got 2 components,1 take care of low speed velocities and the other high speed.
i'm not fully understand that,and i hope someone can answer me.
*sry for my bad english,lol
Where do you rotate the screw?
The fast rotation might lead to something like a compressed (or extended) spring, which reverses the direction to extend (or compress) again afterwards.
Is it a very long screw? Then driving long screws into hardwood I've seen the screw twist due to the high torque. Then when you stop the twist unwinds. It is most noticible on long screws that only have a thread at the pointed end like these...
http://www.screwfix.com/p/timberfix-plus-exterior-timber-screws-6-3-x-200mm-pk50/36687
Could also be a strobe lighting effect?
0xDEADBEEF said:
Does it look like this? http://en.wikipedia.org/wiki/Rattleback
yes,but on an ordinery screw
http://0.tqn.com/d/homerenovations/1/0/A/A/-/-/1-5-8-Coarse-Drywall-Screw.jpg
about spring similarity,why would a hard screw act like 1?
If it is really just a screw I don't think the rattleback explanation works. What is probably happening, is that the screw can roll up on its thread at the tip a bit, when it is spun fast enough. When it comes to a rest it rolls back so the thread at the tip points up again. But if you don't think that is the reason, maybe you should make a video.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
