A plane contains the point A(3, 1, 2) and the vectors u = [-1, 3, 4]
The discussion focuses on finding the scalar equation of a plane defined by the point A(3, 1, 2) and the vectors u = [-1, 3, 4] and v = [2, 0, -1]. The derived scalar equation is -3x + 7y - 6z + 14 = 0, which the user confirms is correct after testing it with various points derived from the parametric equations. The testing involved checking the original point and points obtained by adding the vectors u and v. There is some confusion regarding the need for validation, but the user expresses confidence in their solution. The discussion concludes with a focus on the correctness of the scalar equation derived.
NATURE.M
A plane contains the point A(3, 1, 2) and the vectors u = [-1, 3, 4] and v = [2, 0, -1]. Find the scalar equation of this plane.
I obtained:
-3x+7y-6z+14=0 (for the scalar equation).
Is this correct??
so you tested it with the given pt? and then using the given pt + the u vector to get a new point and again with the v vector?
Yes, I used various points from the parametric equations to test, and it satisfied all. So I feel confident its right. Thanks anyways.
Why "thanks anyways"? If you checked thosed because jedishrfu suggested it, just thank him. If you had already checked, why did you ask?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
