Solve dp/dt Velocity Problem: rho, v, g, f, u
  • Thread starter Thread starter physiker99
physiker99
Object’s above area is S. Dust particles with density rho and velocity v fall over it. Fallen particles on object leave object and fall to the ground. Gravity is g. What is the velocity of the object, u? (Friction coefficient between ground and the object is f)
http://img411.imageshack.us/img411/4336/adszqv0.jpg
Solution is as since there is no acceleration, net force is zero.
Then G+N+ F(friction) + dp/dt = 0
Then x component of dp/dt is calculated as followed: (dpx/dt)
Ffriction = fN = dpx/dt = J * v(relative) = J * (v. Cos(theta) – u) (A)
(dpy/dt > y component of dp/dt)
N = mg + dpy/dt = J * (v*sin(theta)) (B)
J (mass of dusts fall in unit time) = S * rho * v(sin(theta))
Then solver makes derives simple equations from A and B and finds u.
My questioon is, how dp/dt is used. I guess it must be derived, but it is not derived and m*v is directly written.
If anyone understood the solution, please let me know. (Solution is correct by the way, it is taken from a book.)
I am guessing these terms were written as vectors in the book you got it from, rather than as simple scalars as shown here?
Also, "G" is mg, the weight of the object?
The velocity change can be calculated from:
  • The dust has velocity v, at angle θ, before "colliding" with the object.
  • After collison, the dust has the same velocity as the object.
Besides the velocity change, you need to know how much mass of dust has collided with the top surface S per unit time. This is determined by density and volume. The volume is determined from S and v, θ (the before-collision velocity)
If you have more questions, feel free to ask.
You're right, those were written as vectors. Excuse me.
Right, G is the mg (as far a i remember)
How can we use velocity component to calculate mass. Can you explain to me how you use velocity and S to calculate volume? I have difficulty to understand it.
You'll have to use some geometry, and figure out where dust particles are located that would hit the surface within a time Δt later. That will define a volume of space.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
