A question about the Dynamo Theory
  • Thread starter Thread starter zapnthund50
    Dynamo Theory
The discussion centers on Dynamo Theory, which explains how electrical currents in the Earth's molten outer core generate magnetic fields. The participant clarifies that the theory refers to electrical currents rather than molten iron currents, as the latter is electrically neutral. They summarize that a conducting fluid, primarily molten iron, circulates through an existing magnetic field, generating its own magnetic field through motion. The remaining question pertains to the origin of the initial magnetic field that induces these currents.
  • Understanding of basic electromagnetism principles
  • Familiarity with fluid dynamics and convection
  • Knowledge of the Coriolis effect
  • Basic grasp of magnetic field generation
  • Research "Dynamo Theory" through academic papers and resources
  • Study the "Coriolis effect" and its implications in fluid dynamics
  • Explore models of magnetic field generation in planetary cores
  • Investigate the concept of "bootstrap" magnetic fields in geophysics
Students and researchers in geophysics, physics educators, and anyone interested in understanding the mechanisms behind Earth's magnetic field generation.
zapnthund50
I'm studying Dynamo Theory, and have just a few questions. Today's theory says that currents in the molten outer core of the Earth give rise to magnetic fields. Now it would seem that the theory does not mean "molten iron currents", since together that is an electrically neutral substance, but rather "electrical currents", since it is known that a moving electrical charge generates a magnetic field. If this is true, then what induced the electrical currents in Earth's core? Am I grasping the main scientific concept behind field generation, or is there something else I'm missing? Thanks!
You have marked your thread with an "I" tag for undergraduate level education
what have you been reading in your research so far ? so we can gauge where you are at :smile:Dave
Hi Dave,
My appologies, the thread was not meant to be marked undergraduate, but rather basic level. Thanks for pointing that out. Can you comment on the matter of currents?
zapnthund50 said:
Hi Dave,
no problems :)
since I don't know what you have been reading ?
have you read this from Wiki ?
https://en.wikipedia.org/wiki/Dynamo_theory
or this
https://web.archive.org/web/20070221094040/http://setiathome.berkeley.edu/~pauld/etc/210BPaper.pdf
or this
http://www.phy6.org/earthmag/dynamos.htm
or this
http://farside.ph.utexas.edu/teaching/plasma/lectures/node70.htmlthat will keep you occupied for a while :smile:Dave
davenn said:
no problems :)
or this
or this
or this
Dave,
Thanks for all the links. I've thoroughly read each one, and I can say they proved a solid framework for beginning to understand Dynamo Theory. I had read the wiki article before, but the paper on the subject proved invaluable.
Based on what I've learned, the physics of DT can be simplified to the following: A conducting fluid circulates (convection, Coriolis effect) through an existing magnetic field. Moving this conductor (in our case, mostly molten iron) across magnetic lines of force forces a current to be generated. This current will have its own magnetic field. Of course the theory is much more complicated than that, but from what I can gather, this is the physics behind DT. (I think the wiki article was somewhat confusing, as it made no distinction between the physical current of molten iron, and the electrical current flowing through it.)
The only question I have left is, where does the original "bootstrap" field come from? Only one of the links ventured to guess, saying vaguely that weak magnetic fields are always present. All this just makes me want to study one of the many models that must have been made, but I have no idea where to find those. Anyway, thanks for your help.
  • · Replies 0 ·
  • · Replies 84 ·
