Engineering A question about voltage between two points in a circuit
The voltage between points A and B is the same as the voltage between points C and D, and E and F, due to the ideal or nearly ideal conductive wires connecting them, which are assumed to have zero resistance. This means that regardless of current division at point C, there is no significant voltage drop along the wires. While a sensitive voltmeter might detect slight differences in voltage due to non-zero resistance, these variations are negligible for practical purposes. Thus, for the question at hand, the voltages can be considered equal. Understanding this concept is crucial for analyzing circuits with parallel resistor connections.
diredragon
This is a simple circuit diagram from the class were we derived the equations for the equivalent resistance of parallel resistor connection. I have a quick question about this though..
Is the voltage between points ##A,B## the same as voltage between points ##C,D## and ##E,F##?
3. The Attempt at a Solution [/B]
Can someone convince me that they are in fact the same voltages cause even though we said they were i keep imagining that the current which divides at point ##C## and goes through the resistor ##R_1## makes a different voltage than the original and the same goes for the other part. What should i be realizing?
These potential differences are all equal. The basis for saying this is that the conductive "wire" joining points A, C and E is ideal or approximately ideal, i.e., it has zero Ohms resistance. So regardless of how much current that wire carries, there is no significant voltage drop along it. The same applies to the conductor joining B, D and F.
Likes diredragon
For the purposes of the question the voltages are all the same but if you had a sensitive enough voltmeter, a 4 point probe to be exact, you would see slight differences in the voltages all up and down the wires but the changes would be in the microvolt or maybe millivolt difference because although for the purposes of the question the wire is considered zero ohms, nothing short of a superconductor has in fact zero ohms. It might be 10 milliohms or some such but because the resistance is NOT exactly zero there will be voltage differences along the wires. But not enough to change the answer to the question.,
