A question that asks you to figure out the mass of the moon
To calculate the mass of the Moon, the radius and acceleration due to gravity are key parameters. The Moon's radius is approximately one-third of Earth's, and its gravity is one-sixth that of Earth's. Using the formula for gravitational acceleration, g = GM/R², one can derive the Moon's mass as a fraction of Earth's mass without needing the exact mass of Earth. It's essential to set up the problem with the relevant equations to find the solution effectively. Memorizing the mass of Earth may not be necessary if the problem is approached correctly with the given ratios.
Hmpca
the radius of the moon is 1 over 3.65 of the radius of the earth, while the acceleration due to gravity of the moon is 1 over 6 of that on the earth`s surface. calculate the mass of the moon.
The acceleration due to gravity - we call it g on Earth - is given by GM/R2. Where G is the universal constant of gravitation; M is the mass of the central body; and R is the distance form the centre of mass - the radius of the body if we consider g on the surface. You know sufficient of those values to calculate the mass of the Moon as a fraction of the mass of the Earth, which is a value that can be looked up easily.
i thought you could figure out the mass of the moon without knowing the mass of the earth. tomorrow i have an exam and my teacher said don`t expect me to give you any sheet with equations and constants. so i guess i got to memorize the mass of the earth.
thank you
a = GM/R2
g = (1/6)(9.81) = X m/s2
r = (1/3.65)(6.378x106) = Y m
m/r2 = a/G
m/(Y)2 = X/ (6.67x10-11)
m = ANS kg
the person asking for help is supposed to set up the problem, give relevant equations etc. before getting help from outside. Where are your equations??
In answer to your question - you do have to know the formulas probably but not the mass of the earth.
