A rock dropped from a cliff using speed of sound
A rock dropped from a cliff takes a total of 5.1 seconds for the sound of it hitting the ocean to be heard. The problem requires separating the motion into two parts: the time for the rock to fall and the time for the sound to travel back up. The correct approach involves using the equations of motion for free fall and the speed of sound to establish a relationship between the two times. The total time can be expressed as the sum of the fall time and the sound travel time. The discussion emphasizes the need for proper algebraic manipulation to solve for the cliff's height.
ndnkobra
A rock is dropped from a sea cliff and the sound of it striking the ocean is heard 5.1 s later. If the speed of sound is 340 m/s, how high is the cliff?
d=v/t(didnt work)
My first attempt at this problem was to try that formula above, but it was not the correct way to do this problem. I then realized that the time i had was the total time, and that i needed to find the time it took for the rock to hit the water, or the time it took for the speed of sound to go up, which i need distance for. I am now stuck there :(
Welcome to Physics Forums.
You are indeed correct that we first need to determine the time taken for the rock to fall. How do you suppose that we could work that out?
From all i know is that you have to divide your distance by 2. Because you are calculating it from bottom to top.
And why would we want to divide it by two?
Not so simple, rock drops due to gravitational acceleration whereas sound travels at the speed of sound. Division by two is not the answer. Integrate and compare the time lag. 5.1 seconds sounds suspiciously close.
Hi there,
You have to divided the problem in two parts. One where the rock is in free fall. Then, once the rock hits the ocean, the sound is emitted and travels at constant speed.
Cheers
This problem could be interpretted in two ways:
1) the rock is dropped and the total time elapsed is 5.1 seconds until the sound is heard. A two part problem where the two parts will have to be equated to each other in terms of distance.
2) the rock is dropped and the dropper sees it hitting the ocean and hears the sound 5.1s later. In this case it is simply the distance that a sound wave would travel in 5.1 seconds at 340m/s
I would say that it's quite clear that the only correct interpretation is #1. The question clearly states that the rock is dropped and then 5.1 seconds later a sound is heard. It does not say that the rock is dropped it hits the ocean and 5.1 seconds later a sound is heard.
oh nvm got confused with another problem. Sorry.
Okay, so i took the time to look over this problem and separated the problem into two parts. I let d be my distance, so d = (0)(t1) + 1/2(9.8)t1^2. t1 being my first time. I then took d = vt and used the speed of sound for this problem, so d = (340m/s)(t2). t2 being my second time. i then made the problems equal to each other so (340)t2 = 1/2(9.8)(t1^2). I seem to be stuck here, can anyone help me with the algebra in this problem?
Getting warmer...t1+t2=5.1s, so t2=5.1-t1. I therefore can substitute in 340(t2) as 340(5.1-t1)=4.9(t1^2)
