A rocket burns out at an altitude h above the Earth's surface
A rocket that burns out at an altitude h above the Earth's surface, with an initial speed v0 exceeding the escape speed vesc, will have a final speed v very far from Earth defined by the equation v = (v0² - vesc²)^(1/2). The discussion emphasizes the application of kinetic and potential energy principles, specifically the equation KEf - KEi = Ui - Uf, to derive the relationship between the rocket's speed and gravitational forces. The values r1 and r2 are clarified as the burnout altitude h and a point very far from Earth, respectively, where potential energy approaches zero.
  • Understanding of kinetic and potential energy concepts
  • Familiarity with gravitational force equations
  • Knowledge of escape velocity calculations
  • Basic algebra for manipulating equations
  • Study the derivation of escape velocity formulas
  • Learn about gravitational potential energy and its implications
  • Explore advanced topics in orbital mechanics
  • Investigate the effects of altitude on rocket performance
Students in physics, aerospace engineers, and anyone interested in the mechanics of rocket propulsion and escape velocity calculations.
Benjamin Fogiel
A rocket burns out at an altitude h above the Earth's surface. Its speed v0 at burnout exceeds the escape speed vesc appropriate to the burnout altitude. Show that the speed v of the rocket very far from the Earth is given by v=(v02-v2esc)1/2
KEf-KEi=Ui-Uf
I plugged in the values of kinetic and potential energies:
(m1v2)/2 - (m1v02)/2 = (-Gm1m2)/r1 + (Gm1m2)/r2
Simplified to get:
v2=(-2Gm2)/r1 + (2Gm2)/r2 + v02
Im not sure where to go from here
What are ##r_1## and ##r_2##?
Escape velocity for mass ##m_1## to escape mass ##m_2## starting at distance ##r## is the value such that ##(1/2)m_1v_0^2 = G m_1 m_2/r##. In other words, added to the initial potential energy, you get a total energy of 0, which means that the mass ##m_1## will not stop before reaching potential energy 0 at "infinite" or "very far away" distance.
Perhaps that will help?
The intent of the phrase "very far away" refers to the zero point of potential energy. So you can just use 0 for PE.
r1 = h
r2 = "very far away"
Sorry, forgot to define those values.
Yes, that helped! So Uf is essentially zero which then gives me the right answer.
Thank you.
