Is My Coulomb's Law Calculation Correct?
  • Thread starter Thread starter ForrestFire
    Coulomb's law Law
The discussion revolves around the application of Coulomb's Law to calculate the distance of a third particle in relation to two other charges. The user consistently arrives at a distance of 15.47 cm but feels uncertain about their calculations. They set up equations based on Coulomb's Law and canceled out constants, but suspect they may have made an error. Other participants suggest visualizing the problem by drawing a diagram and carefully labeling the forces acting on the third charge. The conversation emphasizes the importance of understanding the direction of forces acting on the charge for accurate calculations.
ForrestFire
http://i.imgur.com/ITrJq.png
F=kq1q2/r^2 (Coulomb's Law)
Whenever I try to get the answer, I keep coming up with 15.47cm.
I found the Coulomb's law for the third particle in relation to the other two, then set those equations to each other. This let me cancel out k and the charge of the third particle, since it wasn't given in the first place. After that it was a simple algebraic solve to find the distance.
But I feel like I'm missing something big, so I'm here for some assistance.
Thanks so much ahead of time! You guys have saved me before. It's only worth one point, which is basically nothing, but I really need to know how to do this.
I tried the problem, thought I had it but made a simple error, one you might be making. If you draw a picture, you might think why bother, and carefully label the forces on the third charge at some point x between the charges you might get it. Note that the forces on the third charge either both act to the left or both act to the right.
Good luck!
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
