Does a Dielectric Rod Alter the Force Between Electric Charges?
  • Thread starter Thread starter FermatPell
    Dielectrics
Placing a dielectric rod between two electric charges does not change the total force exerted on the charges. The electric field inside the dielectric is reduced compared to the external field, but the forces acting on the charges outside the dielectric remain unchanged. The discussion relies on conceptual understanding rather than algebraic equations. The initial assumption is that the force remains the same, aligning with principles related to capacitors. Verification from an expert is sought to confirm this reasoning.
FermatPell
Does placing a dielectric rod between two electric charges increase or decrease the total force exerted on any of the charges?
Not really algebraic, only conceptual.
I guess it remains same...
by placing dielectric ... only the field inside the dielectric becomes less than outside but is same as before outside dielectric ... so no force change is experienced
just a guess
used the concepts of capacitors
Some expert please verify or correct me
