Square Root Problem: Solving for m in s=k√(1+m)/(1-m) | Help & Tips
To solve the equation s=k√((1+m)/(1-m)) for m, start by dividing both sides by k, resulting in s/k = √((1+m)/(1-m)). Next, square both sides to eliminate the square root, leading to (s²/k²) = (1+m)/(1-m). Multiply both sides by k² and then by (1-m) to rearrange the equation, isolating terms with m on one side. The discussion emphasizes that while tricks may exist, most solutions rely on fundamental mathematical principles. Understanding these basics is crucial for effectively solving such equations.
triden
s=k\sqrt{\frac{1+m}{1-m}} , solve for m
Honestly I am stumped, but I do know there is a trick to it. I can't quite remember, but it might have something to do with taking the reciperical or the inverse...maybe the conjugate? Just need a little help getting started.
Thanks,
Chris
Something that would be helpful is to divide both sides by k.
The equation then becomes
<br /> \frac{s}{k} = \sqrt{\frac{1 + m}{1 - m}}<br />
Now, what operation gets rid of square roots?
Ok, got rid of the root by squaring. Now I have this. How can I isolate the m variable?
\frac{s^{2}}{k^{2}} = \frac{1+m}{1-m}
Multiply both sides by k2, then multiply both sides by (1 - m). If you expand both sides, you should be able to rearrange things to get the terms with m on one side, and all the others on the other side.
Something you said at the beginning deserves a comment:
There are probably a few occasions where solving an equation requires some trick that you have to know, but most of the time it's done by plain old mathematical understanding.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
