How Do You Calculate Tensions in a Dual-Block and Rope System?
  • Thread starter Thread starter Darklink8
    System Tension
To calculate the tensions in a dual-block and rope system, the problem involves two 1.0 kg blocks connected by ropes, with an additional rope hanging beneath the lower block. The entire system is accelerated upward at 3 m/s², requiring the application of Newton's second law. The net force equation is Fnet = 2.5 * -9.8 + F, and tensions are calculated using T = g(mass of all things under it). Initial attempts at calculating the tensions yielded incorrect results, indicating a need for clarification or a proper diagram to visualize the forces involved. Accurate tension calculations depend on correctly accounting for all masses and the applied force in the system.
Darklink8
The figure shows two 1.0 kg blocks connected by a rope. A second rope hangs beneath the lower block. Both ropes have a mass of 250 g. The entire assembly is accelerated upward at 3m/sec^2 by force F.
What are the following tensions:
1. The tension of the top of rope 1.
2. The tention of the bottem of rope 1.
3. The tension of the top of rope 2.
Includes the following diagram
[A]
|1
|2
Fnet = 2.5*-9.8+F
T=g(mass of all things under it)
Tsub1 = (.25+.25+1)g
Tsub2 = .25g
But these answers are wrong...
Can't make sense of it with no diagram.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
