What Forms of Energy Change in a Two-Mass Spring System?
In the two-mass spring system, energy changes occur due to the application of a constant force on block 2. Translational kinetic energy increases as the blocks move from rest to motion, while spring potential energy rises as the spring stretches. Vibrational kinetic energy also increases as the system transitions from rest to movement, indicating a change in vibrational states. Thermal energy is considered to change due to the relationship with vibrational kinetic energy, although it is not classified as thermal unless disordered. Rotational kinetic energy does not change since the system does not involve any rotation.
Westin
Two identical 0.25kg blocks (labeled 1 and 2) are initially at rest on a nearly frictionless surface, connected by an unstretched spring, as shown in the upper diagram, where x2=0.059m. Then a constant force of 17N to the right is applied to block 2, and at a later time the blocks are in the new positions shown in the lower diagram, where x1=0.01m and x3=0.108m. At this final time, the system is moving to the right and also vibrating, and the spring is stretched.
I included a picture of the given image.
Check all the forms of energy that change in the point particle system during this process:Select all that are True.
Thermal energy.
Spring potential energy.
Vibrational kinetic energy.
Rotational kinetic energy.
Translational kinetic energy.
None necessary for this problem.[/B]
I know there is a change in translational KE because it start from rest and doesn't end at rest.
I know there is a change in Spring PE because it initially started at rest, and ended in movement.
I know there is a change in Vibrational KE because it initially started at rest meaning very little vibration is
occurring and it ends in movement so that means their is an increase in Vibrational KE while PE is decreasing.
I believe there is a change in thermal energy cause it corresponds to Vibrational KE
I don't believe there is Rotational KE cause nothing is rotating/spinning.
Need help... one try left
[/B]
Also, I am having troubles with this one as well.
2) Check all the forms of energy that change in the real system during this process (assume that the vibrating spring doesn't get hot).Select all that are True.
I know there is spring PE and Translational KE, I don't think there's rotational KE cause its a spring and I think there might be Vibrational KE because it initially starts at rest and ends in motion.
Vibrational energy is not necessarily considered thermal. It only rates as thermal when it is so disordered that it cannot readily be harnessed to perform useful work. A simple harmonic motion would still be considered ordered.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
