A weightless ladder....but why move the pivot point?
  • Thread starter Thread starter mistermill
    Pivot Point
The discussion revolves around calculating the horizontal force required to prevent a weightless ladder from slipping when a person is positioned on it. The initial calculations using the bottom of the ladder as the pivot point yield a force of 272N, while using the top as the pivot results in a force of 56N. The discrepancy arises because the normal force at the bottom, which contributes to torque, is not accounted for when the pivot is at the top. Participants emphasize the importance of considering all forces and torques acting on the ladder, including the normal force and the direction of applied forces. Ultimately, the conversation highlights the necessity of proper force equilibrium analysis to accurately determine the forces involved.
mistermill
A weightless ladder 7.0 m long rests against a frictionless wall at an angle of 65° ablove the horizontal. A 72 kg person is 1.2m from the top of the lass. What horizontal force at the bottom of the ladder is required to keep it from slipping?
Στ=0
τ=FsinθdSolutions for this question always have the pivot point at the bottom of the ladder, solving for the horizontal frictional force at the bottom of the ladder as being equal and opposite to the force at the top.Στ=0
τ person = mgsin25°(5.8)
τ friction at the top= Fsin65°(7.0)
F = 272N
My question is WHY doesn't the answer work if we place the pivot point at the top?
Στ=0
τ person = mgsin25°(1.2)
τ friction at the bottom = Fsin65°(7.0)
F = 56N
What is missing in this solution that would make it correct?
Στ=0
F = 56N
Are you missing one of torques?
Note that there is no mention whatsoever of any friction in this problem. There is only a mention of an applied horizontal force at the bottom, which may or not be friction. What is certain is that the problem explicitly states that the contact with the wall is frictionless.
Not according to the answer keys I have come across. But what about the normal forces at the top and bottom of the ladder? they also don't show up in any of the answer keys. Perhaps that is the 'applied force' at the bottom?
Right, so if the contact with the wall is frictionless, does that mean it can't be used as the pivot point?
mistermill said:
Nope.
The question was clearly rhetorical to make you think about it. The correct answer is yes.
So there is a torque missing when the pivot point is at the top, which accounts for the different answers.
Yes. Can you figure out what force it is?
Edit: Also note that the torques you have taken into account both go in the same direction ... This means that whatever force you are missing must give a torque in the opposite direction with the top of the ladder as pivot.
Is it the Normal force acting perpendicular to the floor?
You tell me. Does it give a torque relative to the top of the ladder?
Well.
I drew my torque from the person straight down.
I drew the applied horizontal force at the bottom as straight out from the wall. So those two torques do act opposite one another.
When I also include a normal force at the bottom of the ladder, it has a torque opposite the torque from the person. Can one have a normal force for a weightless ladder?
Are you sure? In which direction does the force from the wall go? Did you do your force equilibrium in the horizontal direction correctly? Also, if you think about experience in real life, will pulling the ladder away from the wall make it more or less stable?
Note that your drawing being in one way does not make it so, you need to do the math.
What does force equilibrium for the ladder in the vertical direction tell you? Normal forces have nothing to do with weight apart from very often being what balances the weight of an object or other forces acting on that object.
Note that your drawing being in one way does not make it so, you need to do the math.What does force equilibrium for the ladder in the vertical direction tell you? Normal forces have nothing to do with weight apart from very often being what balances the weight of an object or other forces acting on that object.
Gotcha.
Fapplied at the bottom goes toward the wall, causing a torque in the same direction as the torque from the person.
Now we have two unknowns! Because we don't know F normal. A good reason to move the pivot point.
Don't you? What does force equilibrium for the ladder in the vertical tell you?
