How does a receiving antenna separate desired electromagnetic waves?
Receiving antennas separate desired electromagnetic waves by utilizing resonance effects, where they are most sensitive to specific frequencies that match their design. While antennas can respond to a range of frequencies, the tuning circuit enhances the reception of the desired signal while minimizing interference from others. This principle is similar to how human senses, like sight and hearing, are only responsive to certain ranges of electromagnetic waves and sound frequencies. Even when multiple waves coexist, each maintains its identity, allowing for distinct detection. Understanding these concepts clarifies how antennas effectively isolate signals amidst a complex electromagnetic environment.
mak_phy
I don't really know how to put my doubt in words but I will try.
Electromagnetis waves of various frequencies are used for
communication.Also there are EM waves from other sources, for
example even sunlight is eloctromagnetic wave.Now all these
waves are out there in space. So at anyone point in space, it
will be kind of a resultant of all EM waves at that point.
[Like may be if you mix water from various sources ]
So what I think is if it were possible to see the electromagntic
field at any point, we would end up seeing one resultant value.
Now how does receiving antenna separate the wave it wants?
I was syudying science at one time, but forgot, so please
clear my doubt.And bear with me if my question doesn't make sense.
Welcome mak phy,
Rather than "see the electromagnetic field at any point" I would prefer to use the expression detect the field at that point and what you detect depends upon the nature of the detector used.
I am a bit out of my sphere of knowledge with antenae but as far as I know the induced current in a receiving antenna has a maximum value for those frequencies for which there is a resonance effect,that is from transmitter antenae where there is a length and frequency match.The antenna also responds to other frequencies but less strongly and it is the tuning part of the circuit that separates the frequencies.
Hopefully others will come in with better informed comments.When I get some spare moments I will read up on it.
Hi mak_phy, welcome to PF,
Dadface is right, any detection or measurement apparatus is sensitive to a particular range of frequencies. Take for example your eyes. They are sensitive to EM waves in the visible range, but not for example in the radio frequency range. So even though a hypothetical measuring device which was sensitive to both ranges would be able to detect the total field as being the sum of the two (called "superposition") a radio receiver will not detect the visible light waves and your eyes will not detect the radio waves.
Thank you Dadface and DaleSpam for your replies.
I think I got what you are explaining theoretically. Both the resonance part and eyes responding only to certain frequencies. It seems even after interference, individual frequencies don't lose their existence/identity.
I got confused because of the fact that a square wave being made of different sinusoids - all we see is a square wave.
It's the same with sound. The pressure exerted by the air on someone's eardrum has just one value at anyone point in time, and a sequence of values in a duration of time. Out of that pattern we can identify a low-pitched tuba, a high-pitched flute, human voices, bird chirps, car horns, footsteps, heard all at the same time, and we hear the separate E, C, and G notes of a C-major chord.
Thank you both of you for the "LIGHT" and "SOUND" analogy .
That explains it all.
:smile:
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
