About Second Law of Thermodynamics
If a hot object did not emit radiation, it would violate the second law of thermodynamics by allowing heat to flow from a cooler body to itself without external work. The second law dictates that heat transfer occurs naturally from hot to cold, increasing entropy. A hot body emits more radiation than it absorbs in a closed system, maintaining thermodynamic balance. If a hot object could absorb radiation but not emit it, it would gain heat from a cooler object, contradicting thermodynamic principles. A perfect white body reflects radiation without absorption or emission, thus not violating thermodynamic laws.
fxdung
Why if a hot object did not emit radiation then second law of thermodynamics would be violated?
Science news on Phys.org
Every body in the universe emits and absorbs radiation.As far as heat flow is considered it takes place in the direction of hotter to colder body if no external work is done .The 2nd Law of Thermodynamics basically gives the direction of natural(irreversible) process which is the increase in entropy.so your hot body will radiate more than it absorbs if no work is done externally.
If a hot object did not emit radiation but could nonetheless absorb radiation then it would gain heat from a cooler body that did radiate. That would be a 2nd law violation.
A perfect white body does not violate thermodynamics. It would neither emit nor absorb any radiation, but simply reflect it.
Likes vanhees71
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
