Abstract Algebra - Centralizers
The discussion revolves around determining the centralizer C_G(σ) in the symmetric group S_7 for the cycle σ = (1, 2, 3, 4, 5, 6, 7). The initial findings suggest that C_G(σ) can be expressed as kσ (mod 7), where k is any integer not divisible by 7, leading to a representation of the centralizer elements. Participants discuss the challenge of proving this result without resorting to brute force methods and explore more elegant solutions, such as using arbitrary permutations to verify commutativity. Ultimately, the problem appears to be resolved with the help of collaborative suggestions. The thread highlights the importance of clarity in mathematical definitions and proofs.
vsage
I was given this problem to work out but I'm still a little bad when it comes to proofs, but here's the question. I have given it a little thought but I can't seem to prove what I feel is the correct answer without brute forcing the answer in such an ugly way.
Let G = S_7, where S_7 is the group of permutations of the cyclic group (1, 2, 3, 4, 5, 6, 7) (for example (7, 6, 5, 4, 3, 2, 1)). Determine the centralizer C_G(\sigma) where \sigma is the cycle (1, 2, 3, 4, 5, 6, 7), where the centralizer by definition is any element C of the given group such that C\sigma = \sigma C over the given operation. Also, prove that your answer is correct.
Part 1 wasn't too bad: C_G(\sigma) = k\sigma (mod 7), or (k, 2k, 3k, 4k, 5k, 6k, 7k)(mod 7) where k is any integer not divisible by 7, and 0 is taken to be equivalent to 7. Obviously any integer k = 7p + r would produce the same results as k = r for integer p, so I only have to deal with k = 1-6. I hope that made sense: I'm not sure my first way of writing what the centralizer is was correct. However, I'm having trouble producing a proof that I think is acceptable. I think I could easily show that each k satisfies commutativity but it seems so brute-forced. Is there a more elegant solution I can employ? Thanks
Nitpick: S7 is the group of permutations on any 7 distinct objects.
It's clear that each k produces an element of the centralizer... that cycle is simply the k-th power of the given cycle!
Frankly, I think the most straightforward approach is to write down an arbitrary permutation:
1->a
2->b
7->g
plug into the equation of commutativity, and then solve.
(Though, I haven't tried it)...
Helpful as always, thanks! Yeah I meant your definition of S_7, I was trying to paraphrase the question from my notes and it always comes out half-conceived. I think I completely solved it now though with your suggestions.
