septentriones
- 3
This is my first time posting so I'm sorry if the formatting isn't right, just let me know what I need to change. Thanks.
Note: If it helps, I am using "Electronics with Discrete Components" by Enrique J. Galvez and this problem is #4 on page 166.
"The AC supply had a peak voltage of 10 V and a frequency of 1 kHz, and the capacitor had a capacitance of 0.1 μF.
a: Find the peak value of the current through the capacitor.
b: Explain how the current flows through the capacitor.
c: What is the peak voltage between points A and B?
d: We change the frequency of the source so that the peak voltage through the capacitor is the same as the peak voltage through the resistor.
i: What is the value of the frequency?
ii: What are the peak voltages across the resistor and capacitor?
iii: Explain why they are not 5 V."
https://www.circuitlab.com/circuit/87u2sy/screenshot/540x405/
ZR = R
ZC = \frac{1}{iωc}
ω = 2πf
V0 = |Zeq|I0
a:
In this problem, for part a, I found that Zeq = R + \frac{1}{iωc}
and so |Zeq| = \sqrt{R^{2} - (\frac{1}{ωc})^{2}}
From there, I entered what I knew into V0 = |Zeq|I0 in order to solve for I0.
I0 = \frac{V_{0}}{\sqrt{R^{2} - (\frac{1}{ωc})^{2}}}
Plug in with:
V0 = 10 V
R2 = 1000 Ω
ω = 2000π rad/s
c = 10-7 F
I0 = \frac{10}{\sqrt{(1000)^{2} - (\frac{1}{(2000π)(10)^{-7}})^{2}}}
Solve:
I0 = 0.0081 A
I believe this is the correct solution for part a but I am not quite confident with it.
b:
From what I have read, I am pretty sure that the current is 90° out of phase with the voltage when it flows through the capacitor but I would appreciate it if someone could explain to me how to understand phase shifts. I understand at a high level but mathematically I don't really know what to do.
c:
The current is the same everywhere since the circuit is in series.
Vab = I0ZC
Vab = I0 \frac{1}{ωc}
Vab = (0.0081)(\frac{1}{(2000π)(10^{-7})}
Vab = 12.89 V
This does not seem like it should be possible to me so do I treat it like a DC circuit instead and:
VR = I0ZR
VR = I0R
VR = (0.0081 A)(1000 Ω)
VR = 8.1 V
and then subtract from the peak voltage?
10 V - 8.1 V =1.9 V ?
or from the 12.89 V calculated before?
I don't really understand how to approach this aspect of AC.
d:
i:
VR = I0ZR and VC = I0ZC
VR = VC so ZR = ZC
R = \frac{1}{ωc}
ω = \frac{1}{Rc}
ω = \frac{1}{(1000)(10^{-7})}
ω = 10000 rad/s
f ≈ 1591.55 Hz
ii:
The peak voltage will be the same for both (since that is the state of the problem) but I first need to find the peak current again.
I0 = \frac{10}{\sqrt{(1000)^{2} - (\frac{1}{(10000)(10)^{-7}})^{2}}}
I0 = \frac{10}{0}
Here I run into this issue and I don't know where I made a mistake.
iii:
I can't really answer this yet.
Thank you for any help. I really want to understand this.
