Accelerating force due to ejection
The discussion centers on calculating the accelerating force of a festival rocket that ejects 0.05 kg of gases per second at a velocity of 400 m/s. The relevant formula, F = dp/dt, represents Newton's second law, indicating that the net force is equal to the rate of change of momentum. Momentum (p) is defined as mass times velocity (p = mv), and in cases where mass changes, the formula must account for this variation. The detailed breakdown shows that for rockets, the force can be expressed as F = m dv/dt + v dm/dt, emphasizing the importance of using the correct version of the equation for varying mass scenarios. Understanding this formula is crucial for accurately determining the force exerted by the rocket during its operation.
Jowin
A festival rocket is ejecting 0.05 kg of gases per second at a velocity 400m/s The accelerating force on the is? The formula given in the book is F=dp/dt What does the formula mean:confused:
The formula is known as Newton's second law and states that the net force acting on a body is equal to the rate of change of the [linear] momentum of the body.
Welcome to PF!
Hi Jowin! Welcome to PF! :smile:
I'll just add:
p is momentum, which is mass times velocity: p = mv.
F = dp/dt is the official version of good ol' Newton's second law …
so it's F = d(mv)/dt = m dv/dt + v dm/dt, which for fixed m is F = m dv/dt, which is probably what you recognise. :wink:
But for space rockets and festival rockets, m changes, so the official version has to be used! :biggrin:
